Brief Description: Tightened and Torqued Final Four Spar Bolts
The bolt going thru the spar and the right fuel side cover had to be removed so that the bolt next to it could be tightened. After that was completed, the other three spar bolts were tightened and torqued. The nuts had torque seal applied.
