Brief Description: Drilled Left Side Cover for Spar Bolt
The fuel lines were bent so that they would not touch the floor brackets. One small bend would cause other points in the line to move, requiring the line to be bent.
The left side cover was positioned so that the spar bolt hole could be marked and drilled. The Unibit was used to drill the hole. A bolt was placed thru the hole into the spar. The top cover needs to be placed in position to check the hole alignment.
A bolt is in place thru the side cover on the spar
