Brief Description: Made a Second Aileron Control Stop-Unusable
A second length was cut off the Delrin rod, along with an aluminum tube, for the left aileron. The Delrin rod was drilled with progressively increasing the drill bit sizes. As the holes got larger, the hole got off-line. The Delrin tube will have to be remade.
