Brief Description: Left Wing Nav Light Power Wire Redone
I connected the left wing spare wire to a spare battery. A ground wire was connected to the battery. The left nav lights came on, indicating that the wrong wire was connected to the nav light power wire into the P-1. The nav wires were cut apart. The spare wire was relabeled. The new spare wire had the end covered with heat shrink.
The new left power wire was crimped to the right wire and the single power wire. A short wire was added to the single wire in the connector. Heat shrink was applied to the wires and over the connector. The master was turned on and this time all of the nav lights work!
Right nav lights on
Left nav lights on
The single wire on left is the P-1 light power wire
