Brief Description: Ran Nav Power Wire thru Left Wing
With John C.'s help, we ran the nav power wire thru the left wing, along with a second spare 18 ga wire. We began with the same problem as with the right wing. The wire could not be pushed past the tie wrap that had been placed on the third rib inboard, because of the kink in the plastic conduit. We ended up pulling the strobe wire back into the fuselage and then pulling the plastic loom back into the fuselage and then pulling the loom from the access panel out of the tie wrap. The strobe wire and the two lengths of 18 ga wire were placed into the plastic conduit outside of the wing. John had brought plastic rods that could be connected to together with a loop at one end. One of the wires was looped thru the plastic rod loop and taped together. The combination of the plastic loom with the three wires inside were pulled thru the wing.
