Brief Description: Ran Nav Power Wire thru Right Wing Loom
The nav power wire was run thru the right wing in the wire loom. It would not go past a tie-wrap on a rib that was close to the fuselage, so the wire was pulled out.
The end of the strobe wires was separated and one wire was stripped. A curl was put into the end and then soldered. A length of sagety wire was tied and taped to the curl. This would allow the strobe wire to be pulled into the conduit in the wing and still be pulled out. The strobe light wires were marked at the access panel location and then pulled into the cockpit. The nav power wire was taped to the strobe wire at the marked point. The wire was untaped at the access panel and pulled thru. The wire still could not be pushed thru the conduit at the outboard wing, so the strobe wire and conduit was pulled into the access panel. The nav power wire was run thru the conduit and then everything was run back thru the wing.
