Holes were drilled thru the vertical bracket on the left lower sidewall and inserted plastic grommets. The pitot and static tubing were run thru the holes above the oil cooler door control. The plastic tees that will be inserted in the pitot and static lines for the AOA inputs had the clear and red lines inserted on the barbs. The pitot and static lines were shortened for the tees and the extra tubing. Plastic inserts for the tubing going into the tees were pressed into the tubing and then heated slightly with the heat gun. This allowed the insert to be fully inserted into the tubing.
The Fuel Guardian wires need to be screwed into the controller. The controller was already screwed onto the subpanel, along with the wiring for the lights. One screw was removed and another was loosened.
The AOA tees attached to the pitot and static tubing
