Brief Description: AOA Tubing/Moved Pitot and Static Lines
The blue and green tubes from the AOA holes in the right wing were run along the smoke oil hose in the cockpit and then up behind the map box. They were then attached to the AOA computer box.
The bracket holding the pitot and static tubes in the Adel clamps was removed, because of interference with the rudder cable. I tried rotating the bracket upside-down, but that did not change anything. A hole was drilled in the stringer above and the bracket was clamped to that. This fix should work a lot better.
