Brief Description: Nuts/Washers on 3/16'' Bolts/Bottom Spar Doubler
The nuts and washers were installed on the remaining 3/16" bolts along the wing spar.
The brass rivet set was used to insert the NAS bolts thru the lower spar section and doublers on front and aft sides. Nuts and washers were installed on the bolts.
