Brief Description: Installed Most of the Spar Bolts
With Ed Hanic's help, more bolts were inserted in the wing spar holes. We got almost of the 3/16'' bolts installed. Most of the bolts had nuts and washers installed. We had to make two openings in the far right rib because the bolt was too close to the rib. The Dremel was used to make a half-moon opening for each nut in the top and bottom holes.
