Brief Description: Fuselage Holes for Wires/Fuel Selector Valve
The final cleaning of the shop was completed. The last of the stuff was loaded up in the car and taken to the hangar.
The Unibit was used to debur the inside of the holes drilled in the fuselage side for the wiring and AOA tubing. I discovered that the Unibit used to drill the AOA hole nicked the doubler inside the fuselage. This will need to be smoothed out. Plastic grommets were placed in the holes.
The fuel selector valve was taken apart, because store hardware was used to connect the valve to the bracket.
Holes in the fuselage for the wires from the left wing
