Brief Description: Patched Nav Light Hole/Painted Wings
Walt Halloran patched the nav/strobe light hole in the right wing tip. The edge of the circular nav light hole had been sanded too much at one spot, leaving a nick to be patched. Walt cleaned up small areas that had not been prepared properly before priming. He then painted the wing components a base white with two coats and then used Toyota White paint for one more coat. The top of the wings, ailerons, and the flaps each got two coats of the Toyota White.
The nav light opening that was patched
The trim tab, wing tip, flap and left aileron painted
