The AeroLED lights require 20 gauge wires. I could not find any 20 ga, so I decided to use the shielded 3-wire runs and connect the pairs to each other, then to the AeroLED connectors. The wires in the shielded wiring are 22 ga. The wires were run thru the plastic tubing in the left wing and then thru a wire loom. The pairs were crimped to a single wire each for the power, master output and slave input. The single wires would be placed in the 5-pin connector. The pairs of wires had heat-shrink applied. The wires were then labeled.
