Baker's RV-6
RV-6
Pitot Tube-Nutplate/Shortened Tubes
Holes were drilled and a nutplate was riveted to the main spar by the left wing access hole. This nutplate will be used to clamp the tubes for the pitot system.
The aluminum tubes on the pitot tube were shortened with a tube cutter.
The nutplate on the main spar
The aft side of the main spar
The pitot tube with the cut aluminum tubing
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
