Baker's RV-6
RV-6
Drilled Tip Rib to Left Wing/Visitor
Pilot holes were drilled in the rib. The tip rib was taken off the left wing. The rib was clamped to the wing tip and back drilled to the tip.
Visitor-Rod Brulz
I worked with Rod on riveting solid rivets. Rod is building an RV-12 and needed help with his instrument panel.
The tip rib drilled to the wing tip
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
