Brief Description: Helped Epoxy Reinforcements on Oil Door
Walt Halloran helped me epoxy the reinforcement piece around the oil door opening, along with a aluminum striker plate. The plate had numerous holes drilled in it so that the resin would fill in between the cowling and the reinforcement for more strength. Everything was then clamped into position.
The striker plate
The reinforcement piece and the striker plate epoxied to the cowling
