Brief Description: Cut Aluminum Strips for Wing Tip Reinforcement
All of the holes in the wing tip had to have aluminum doublers under the rivet holes. Strips of aluminum were cut out of .016'' material. The strips were then clamped to the wing tip and drilled to the wing tip. Holes for the nutplates were then drilled.
