Brief Description: Installed Nutplates in Fuselage and HS
The left side of the fuselage had a #6 nutplate riveted in place. The hole under the HS thru the longeron was tapped for a #6 screw. The holes in the underside of the HS were drilled for the nutplates.
The nutplate in place on the left side of the fuselage
