Brief Description: Drilled the Right Wing Fairing to the Wing
Pilot holes were drilled in the right wing. Using a strap duplicator, the right wing fairing was drilled to the fuselage. A length of 3/16" tape was applied over the right wing root fairing next to the fuselage. Painter's tape was then run along the edge of this strip of tape and the 3/16" tape was removed. The aluminum showing would need to be sanded off the fairing, so that the rubber trim would lie properly against the fuselage.
