I took photos of the inside of the fuselage where the nutplates need to be riveted for the empennage/fuselage fairing. The right side will use a doubler under the nutplate, because the screw hole was drilled thru the bulkhead flange. The left side might need to be redrilled for the rivet holes. Both nutplates will probably be one-eared.
