Brief Description: Drilled Hinge to Cowling and Oil Access Door
Walt and I drilled the hinge to the oil door and then to the cowling. The hinge was clecoed in place and we found that the door would not open properly. We had set the hinge too far away on the door from the cowling, which restricted the door opening.
Walt took the door with him and gave it to a friend who was able to weld the holes closed.
