Brief Description: Riveted Hartwell Latches to Oil Access Door
The latches were drilled to the oil access door with a #30 bit. The holes were countersunk. Walt sanded the door prior to riveting so that the latches don't get scuffed by sanding. The door is ready for priming and painting. The latches were riveted to the door using the pneumatic squeezer. The latches will be sanded to a shine later.
