Brief Description: Changed Out Hobbs Meter Pressure Switch
I received a new Hobbs meter pressure switch from B & C Specialty Products. This switch has both terminals: normally open and normally closed. The yellow wire to the light was screwed onto the NC terminal and the ground wire (white) was screwed onto the COM ground terminal. Now the Low Oil Pressure light works on the panel without the engine running.
