Brief Description: Ran Wire Thru Firewall for Low Oil Pressure Light
With Walt Halloran's help, the 18 gauge yellow wire to be run between the Hobbs meter pressure switch and the P-1 connector. I crawled under the panel and Walt pushed the wire thru using a coat hangar with the wire taped to it.
