Brief Description: Tightened Fitting on Manifold Transducer
Fuel Lube was applied to the fitting threads on a straight fitting. The fitting was screwed into the top hole of the manifold transducer. A plug was screwed into the opposing hole. An Allen wrench was used to tighten the plug, but it felt like the plug was cross-threaded. The plug was removed and reinstalled a few times. Eventually I left the plug out.
