Brief Description: Rerouting of the Oil Line for Hobbs Meter Switch
With Walt's help, we figured out how to get an oil line to the Hobbs meter switch on the manifold. A #4 tee fitting, AN824-4, is required. The oil line to the oil pressure transducer will be split in two. The tee fitting will be inserted in the middle and another steel-braided line will be attached to the fitting and run to the manifold next to the Hobbs meter switch. The opposite hole on the manifold will be plugged.
