Brief Description: Trim Cable Indicator/Allowable Bend in Cable
The trim position indicator that was made by Bill Repucci was inserted into the handle of the trim cable.
The housing of the fuel selector and the trim cable was screwed together. The cable was bent back around to test the angle and make sure the cable would still operate. The cable could be bent and run thru a hole as high as 4 1/2" high from the base, if necessary.
