Brief Description: Installed Clip for Support Rod/Visitors
The clip to hold the tip-up support rod was installed on the aft vertical bracket. Two holes were drilled and the clip was installed using #8 screws, washers and nuts.
Heat-shrink was placed on the rod where the rod goes into the clip to protect the paint.
