Brief Description: RTV under Clock/Quick Disconnects in TruTrak
Blue RTV was applied under the clock, since the clock was setting so close to the canopy deck.
I discovered that the TruTrak autopilot needs pitot and static inputs. Two quick disconnect plugs were screwed into the ADI, but the static plug was not screwed into the hole straight. I believe that a good seal was made. Two additional T fittings were added to the pitot and static lines so that lines could be run to the ADI. Tubing was cut and inserted into the plugs.
