Baker's RV-6
RV-6
Bolted Windshield Center Support Rod
The bolts were inserted into the support rod and the rib and brackets. I was able to tighten both nuts. The top of the rod had its bolt tightened, after adding the brackets for the sunshields.
The fuselage
The bolts and nuts on the center support rod
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
