The Zaon XRX will be incorporated into the Garmin 496. The Garrmin data cable had to be disassembled from the 9-pin connector. The data wire from the Zaon will be added to the data wire for the 496. The pin removal tool was used to push the pins out of the connector, but a few pins were broken in the process and need to be replaced.
The 496 data cable removed from the 9-pin connector
