The antenna coax and the pitch servo wires were tie-wrapped to the floor brackets for now, to keep them from moving around. The antenna wires were run upward along the left side of the center of the firewall. The pitch servo wires were run upward along the right side of the firewall and tie-wrapped to the other wires. An Adel clamp was installed on the rudder pedal overhead bracket to hold the antenna coax.
The headset wires thru the P4 connector were clamped to the new bracket attached to the control bracket under the instrument subpanel. The clamp holding the throttle cable was also moved to the new bracket. Another clamp was added to the new bracket to hold the Comm 2 antenna coax. The Comm 2 coax was screwed onto the backside of the panel above the Emergency Com 2 Bypass jack. The coax from the radio runs to the jack below the Bypass jack.
The wires tie-wrapped to the floor
The antenna wires clamped
The P4 headset wires run parallel to the instrument subpanel
