The flap wires that were removed and will be unused had heat shrink applied over the terminals. The correct flap wires were connected to the flap switch. The wire that had been runned thru the elevator control tube tunnel as a common ground was cut and then removed, as it is now unnecessary.
Two lengths of coax were cut for the two commantennas. BNC connectors were added to one end on each cable.
