Brief Description: Made Bracket for Attaching P4S Connector
The wires for the P4S connector run under the control cables. The extension that was riveted to the subpanel has room for a bracket that can be extended below the cables. This bracket was made of 1/16" angle and drilled to the extension. The bracket had a smaller bracket riveted to it so that another clamp could be added for the throttle. This bracket will let the throttle set lower and add a little more length so that the cable will go thru the cover better. Two nutplates were riveted to the brackets.
Bracket for P4S connector
Nutplates riveted to bracket
The bracket in place on the control bracket on instrument subpanel
