Brief Description: Pinned P4S Connector and Clamped in place
The backshell of the P4S connector was pinned with the headset wires from each side, along with the power wires for the LEMO plugs and the ground. The P4S connector was screwed into the other end. The wires on the left side were interlaced with some other wires clamped to the subpanel flange. The right set of wires were clamped to the bracket under the map box.
The P4S connector
The right side set of wires clamped under the map box
