The headset jacks were unscrewed from the holes on the left side. I placed a long board across the canopy rails and use wires were trimmed back. This was used as a work surface. The solder was removed from the jacks, along with the wires. The wires were trimmed back. The left LEMO plug was removed the the shielded wres were pulled out of the wire loom. The wires were shortened to about twelve inches long and the ends were readied for soldering to the jacks. One strip of about five inches was cut off the white/white and blue wire. The wires were separated and the white/blue wire was pulled out. This wire was connected to the same colored wires on each jack and wrapped together. The other LEMO wires were wrapped with the appropriate jack wires. Heatshrink was applied over the areas where the shielding was cut away. The wires were then soldered to the jacks.
