Brief Description: Jacks installed on Left Side/Wire Sleeve Used
All of the headset wires were labeled by the jack and at a point about four feet farther along. The mic and phone jacks were screwed in place on the left bulkhead. The wires were run through the grommet and the bulkhead. Two screw holes were drilled in the underside of the armrest bracket so that the wires could be clamped underneath. The wires, including the LEMO wires, were run through about three feet of wire sleeve. The wire sleeve had heat-shrink applied at both ends. Adel clamps were screwed in place holding the wires under the armrest. Another hole was drilled forward of the next bulkhead and another clamp used to hold the wires.
The left headset jacks in place with the wires placed in wire sleeve
