Brief Description: Applied Heat to Plenum to Improve Clearance
One way to lower the plenum is to lower the center section by heating the area with a heat gun. I applied heat to various areas of the plenum and then tried to push it down with a 2x4 block of wood. The plenum did not move downward very much.
