The ram air door control arm was shortened by about an inch and a hole was drilled in the end for the B-nut. The carb heat inlet bracket was completed and then drilled to the carb heat inlet. A slot was cut in it for the carb heat control cable. Holes were also drilled in the bracket for the tube hangars to be bolted to it. The bracket and the carb heat inlet were placed on the air filter and the filter was placed on the engine. The rubber tubes were shortened so that they fit between the tube hangars.
The completed bracket
The carb heat cable clamped to the new bracket
The exhaust hangars used to support the air filter
