Baker's RV-6
Date:  1-25-2012
Number of Hours:  1.00
Brief Description:  Removed and Marked the Carb Inlet for Trimming
The carb air inlet was removed from the carburetor. The Scat tubing was placed on the inlet and its most forward position was marked. A clamp was laid on the inlet and its position was also marked. This is the most forward point for trimming the inlet, in order to allow the air filter housing to be positioned inside the cowl.
The most restrictive trimming line on the carb air inlet
