Brief Description: Lower Cowl in Place/Air Filter Housing in Cowl
I found that the carb air inlet will need to be cut back, in order to allow some length of 3" Scat tubing to be installed between the inlet and the housing.
The cowling on the engine with the cowl air inlet ring in place
