Brief Description: Plenum Baffling/Transferred Carb Holes to Air Filt
Tim Conway looked at the front of the plenum where I had been planning on trimming and reglassing in order to get a tighter seal on the engine. His suggestion was to instead use strips of baffling seal riveted to the front of the plenum. He also suggested bending the two fromt pieces of aluminum baffling downward more to match the angles of the plenum's air inlets.
Tim also located the holes to be drilled in the air filter to match the bolt holes in the carburetor.
