Brief Description: Some Fairings Drilled to the HS, VS and Control Su
The holes to attach the fairings to the left HS and the left elevator were laid out and drilled to #30. The fairings were drilled in place. I didn't realize it until after drilling the elevator fairing on the top side, that the fairing stuck out farther than the HS fairing. The fairing will need to be adjusted. The top rudder and VS fairings were drilled in place. The right HS and elevator were marked in preparation of drilling pilot holes.
