Brief Description: Right Injector Installed/PK Screw in Heat Muff
The hole in the right exhaust was enlarged to #41 hole for the PK screw. The screw will hold the forward ring bracket of the heat muff in place so the muff does not rotate.
The right exhaust was rotated back into position and the exhaust bracket was tightened. The injector was tightened on the hose and then inserted into the exhaust. The injector was clamped in place and then safetied. The hose was clamped to the engine mount.
