Brief Description: Drilled Injector Hole in Right Exhaust/PK Screw
The smoke hose for the right injector was routed around the engine mount and clamps were placed into position. Mouse milk was applied to the ball joint on the exhaust in order to be able to rotate it. I drilled the right exhaust pipe for the smoke injector.
Tom Cullen had suggested that PK screws should be screwed thru the sides of the carb heat muff and the heat muffler into the exhaust to prevent rotation. The heat muffler had the cover removed and one #41 hole was drilled in the exhaust. One side of the muffler was removed and a #40 hole was drilled in it. I attempted to screw in a truss head #4x1/4" sheet metal screw with no luck.
