Baker's RV-6
Date:  10-13-2011
Brief Description:  Clamped Ignition Wires/Firewall Pass-thru
The Lightspeed ignition wires were clamped to the engine mount just behind the baffling.
The EGT, CHT, amps lo and high, alternator low voltage and field relay wires were wrapped in the firewrapping and then pushed in the firewall pass-through. The clamps were applied and the firewall pass-through on the right side was finished.
The left side
The left side
The Lightspeed wires clamped
The right firewall pass-through
