The plastic covering on the two coax wires for the Lightspeed ignition was cut and then pulled off, exposing the shielding. The coax has two layers of shielding and the shielding was spread apart, using a dental pick. When a large enough opening was created, the center plastic covering over the wire was pulled thru. The coax wires had red terminals crimped onto them and the shielding was wound in order to fit into blue terminals, which were crimped in place. Heatshrink was applied over each terminal.
