Brief Description: Ran Lightspeed Power Wires thru Baffle
The aft baffle pieces were drilled to 9/16" size for the rubber grommets. The grommets were inserted and the RG-400 wires run thru the grommets. I took off about 1 1/2" of the top wire cover on one wire in preparation of adding terminal ends.
