Brief Description: Tied Up More Wires/Ground Wire for Tanis
The Tanis preheat wires for the front cylinders were added to the ignition wire clamps for the same cylinders. The Tanis wires were then tie-wrapped to the ignition wires going aft. The EGT and CHT wire leads were also added to the tie-wrapping with tie-wraps separating them from the ignition and preheat wires.
The EGT and CHT wires for the right side, cylinders 1 and 3, were shortened and the terminals were clamped to the wires.
The ground wire for the Tanis preheating system was attached to the screw that holds the right rear baffle to the engine block.
