Brief Description: Installed Terminal Nipples on Master/Starter Relay
Two small terminal nipples were inserted on the terminals of the J1 and P3 wires that are attached to the Master Relay and Starter Relay. The wire terminals were reattached to the relays and then the nipples were pulled over the bolts and nuts.
